Baja 240 rpm question >
Old 06-07-2010 | 03:58 PM
Default Baja 240 rpm question
I just bought a 88 baja 240 sport, with a 454 mag. I am running a 4 blade prop, not sure the pitch but im sure its around the correct pitch for the boat (22-25) The boat runs 4100 rpm @ WOT. can't quite get to 60 mph. Does this sound normal for this boat?
astar77350 is offline
Old 06-07-2010 | 04:01 PM
sorry..listen to those ,,who are slow !!!!
DareDevil is offline
Old 06-07-2010 | 06:05 PM
There is now way that boat will do 74 mph with a 454 mag. I think 64 would even be a stretch.. On GPS that is.. I do agree you need to be turning more RPM. With a smaller pitch prop you will come out of the hole better and prob pick 4-5 mphh on top.. Those boats like 3 blades for speed and 4 blades for Skiing or tubing.
Chris
Originally Posted by DareDevil
No,,,a 454 Mag needs to run at
5200-5400 RPM so i think your prop is to big or something else is wrong..timing maybe or so.
A buddy had 1 just like it with a 454 mag and a 23 mirage ( 3 blade ), boat ran right at 74 MPH !!!!!
So with a 4 blade it should be a 21-22 pitch prop !
Blueabyss is offline
Old 06-07-2010 | 06:20 PM
74 is a strrreeetttccchhhh..I have a 502 in mine, and turn a 26 bravo..but I have my x demetion raised 3 inches...
stlliberator is offline
Old 06-07-2010 | 06:28 PM
He does that all the time. He is just trying to stir things up.
You should prop the boat for about 5000 RPM. A Mag engine has forged internals, you can run a mag engine higher in the RPM range if it does not have a limiter. The cam is not designed to build power after about 5000 RPM, you will most likly not go any faster. A 3 blade 23p mirage prop should work the best for speed. You should see about 61 or 62 on a GPS. If you do not see these sort of numbers try checking the timing, replace wires, plugs, cap ect...
jeffswav is offline
Old 06-07-2010 | 06:55 PM
AIR TIME's Avatar
when my baja 24 was new in 88 it had a 454 330hp and did 62 on speedo, a friends had a 454 mag365hp did 64 speedo, I also moved up to a merc 502 in 93 390hp was getting 67 on speedo. props were mirage 23 non plus, for the 454s and 25 for the 502. the drives are deep on these boats so up grading to a imco 2'' shortie gives better handling and speed but you need a 1990 b1 drive or newer the 88 drives had a smaller case and different inside.
AIR TIME is offline
Old 06-07-2010 | 07:18 PM
lol
Old 06-07-2010 | 07:29 PM
jeff is rigth and airtime!!!i have the same boat 365mag 150 bravo drive 21mirageprop did 62 on the stock speedo back then i didn t have a gps so i dont no the real speed .
bajabob is offline
Old 06-07-2010 | 07:33 PM
the baja likes mirage props 3 blade. if you want to run a 4blade you have to go down a pitch. so i would put a 20 or 21pitch . like they said 5000is what you want to prop your boat
bajabob is offline
Old 06-07-2010 | 07:37 PM
lol
