Bravo One Drive for Parts, Upper and Lower
Bravo 1 drive w/low water pick up for parts both upper and lower. 1.5 Gear ratio. This was hooked up to a stock 454 motor. I unfortunately had a bad mechanic that didn't tighten the top nuts on the drive, I put a few hours on it and bang it blew out the gears because the top cap flew right off the drive. The shafts are good and the cases are good. The lower will need to be taken apart to clean out any metal shavings that fell down in but other than that the lower is intact.
Send me a PM and I'll send detailed pics of everything. All of it has to go, make an offer for some or all of it.
