Priming Oil Pump >
Priming Oil Pump
Priming Oil Pump
Old 06-10-2010 | 11:08 AM
Default Priming Oil Pump
I have a new 2006 6.2L that has been stored in the crate for 4 years. It was serviced with an engine storage product at that time. I am getting ready to install and have changed the water pump impeller and drained (let sit for a couple weeks draining) and today I replaced the oil. I have removed the plugs and serpentine belt and gave each cylinder a squirt of Dexion. Initially I gently turned the crankshaft with a wrench and rotated it several times. The engine turns freely with the starter motor hot wired. I have cycled it atleast 15 times and expected the pump to push oil up to the filter location but nothing so far. I pulled one of the oil pressure senders off and there is oil there. Am I primed or should I keep cycling untill it reaches the oil filter mount on the top of the engine?
boatnuts is offline
Old 06-10-2010 | 10:14 PM
Put a cheap manual oil pressure guage on it, pull the distributor, and prime it with a drill and oil pump priming tool. It will make you feel better to just be sure. I can easily make 50psi on the drill in my motor. You may want to consider some valve springs after sitting that long.
tx911 is offline
Old 06-11-2010 | 03:38 PM
Jerry B
Is'nt the oil pump on that engine at the front and driven directly off the crankshaft? We have a tool to prime the oil system. consist of a small tank. Holds about 4 quarts of oil.
It has a hand pump on it. You screw the line into the hole where the oil sender goes and push oil thru the system.
Jerry B is offline
Old 06-11-2010 | 05:01 PM
boatnuts,remove the sparkplugs,ground the ig system,and crank the starter for 30 seconds,your system will be primed,replace plugs,and your good to go.
mike tkach is offline
Old 06-11-2010 | 08:01 PM
Registered User
Oh Boy
CSCinc is offline
Old 06-11-2010 | 08:05 PM
blue thunder's Avatar
That is what I would do.
blue thunder is offline
