Converting from Triple O/B's to Twin O/B's? >
Old 06-11-2010 | 01:57 PM
Default Converting from Triple O/B's to Twin O/B's?
If someone were considering swapping three outboards for a pair of newer outboards, would the boat still use the same placement as the port and starboard outboards?
Im confused as to if the motors are spaced differently on the transom when you have three versus two motors. Could you remove the center engine and run the boat with twins without having adverse affects to the handling?
Are triple o/b boats laid up specifically for triples?
waterboy222 is offline
Old 06-11-2010 | 05:21 PM
wot
Registered User
Cat -or- V?
Yes -or- No, same question would apply to a twin setup.
Yes -or- No (see above)
Yes -or- No, maybe Transom and/or a Pod (cat)
wot is offline
Old 06-11-2010 | 05:29 PM
If there is a bracket, NO you need one for twins with 26" spacing. If you remove the middle motor the outboard motors will be too far apart. Is this on a V hull ? "HIGH LIFE"
HIGH LIFE is offline
Old 06-11-2010 | 08:00 PM
FeverMike's Avatar
Nope the 2 outside outboards are to far apart for a V bottom.
FeverMike is offline
Old 06-12-2010 | 07:20 AM
The boat he is talking about is a 30 Spectre Cat. Depending on how the boat was rigged the outer two motors should be in the right location.
Maritime_Eng is offline
Old 06-14-2010 | 08:35 AM
Sea-Dated's Avatar
Step 1,
Buy a boat......
Sorry Cale, I just had to.......
Sea-Dated is offline
Old 06-14-2010 | 10:02 AM
Its on a cat, yes. The 30 spectre that was mentioned earlier. So if the center engine was removed and the shifters/throttles were replaced with a twin setup everything should be kosher running the two outside engines alone, right?
Old 06-14-2010 | 10:03 AM
Originally Posted by Sea-Dated
Buy a boat......
Thats the general idea! I just dont want something thats gonna be sittin in the driveway in pieces because I didnt do my research first!
Old 06-14-2010 | 10:08 AM
No reason to buy this year, U got a new cig coming soon.
JohnnyMarshall is offline
Old 06-14-2010 | 10:22 AM
I know, right?! But I still would MUCH rather prefer to be behind the throttles!
