Aluminum Trailer Restorer
What do you guys use? I just had my all new u-bolts and nuts replaced, new HD springs, disc brakes, recarpeted the bunks, and a new actuator put on the trailer. The aluminum was looking a little pitted. I used MOTHER's aluminum polish and it came out OK, but not great. I heard "brasso"? was good but I cant seem to find it anywhere. Any suggestions on what to use and how to use it would be greatly appreciated. Here's a before and after (different sides)
Regular dishwashing soap, water, and a stainless steel wool pad... going with the grain. Will this removing the pitting AND bring back the shine? Or should I use the stainless steel wool and than reapply the polish? Thanks for the reply's guys!
You can apply the the polish with the steel wool and then wipe off. Alot of work but turns out well, depending on how much elbow grease you apply....
We decided to test first. We used the Brillo type steel wool pad on the inside of of a main beam. Looked perfect....twice wet in fresh water and right back to where we started. For us, it was the same as trying to polish a lower case on an outdrive...won't last.
It is also enough work to consider hiring $10 hr day laborers.
