What size oil cooler and fittings? >
Old 06-14-2010 | 12:32 PM
Default What size oil cooler and fittings?
The oil cooler is still stock from the 502 EFI (now a 509 with much more power). I notice my oil pressure dropping after running hard for very long. Been through all the hoses, pumps, etc and I have figured this motor is much tighter than the old 502 and with the additional power and RPM's the cooler just doesn't have sufficient capacity. Anyone have a recommended size (or even what the stock is so I can go larger) plus...
What size are the fittings ( I am assuming 1/2 inch) for you technical spec guys. thanks for the help.
knockld is offline
Old 06-14-2010 | 01:40 PM
I use a EMI 3" oil/ps cooler, it has 18" for oil and 4" for ps. I use the 12AN fittings and hose, they are expensive. There are some other options that are less expensive. Do not use the factory stuff, it is way to restrictive. Do a search, this topic has been covered many times.
jeffswav is offline
Old 06-15-2010 | 02:21 PM
AIR TIME's Avatar
call mr. cooler he is on here in the new parts or what ever they call it, its above the swap thread. he is building new coolers for my big blower motor.
AIR TIME is offline
Old 06-15-2010 | 04:49 PM
ditto. call Mr. cool. he got me (what looks exactly like a hardin) combo thermo controlled cooler.
Fixxxer22 is offline
Old 06-16-2010 | 12:40 PM
I will get in my boat this weekend to see how large the inlet and outlet water hoses are and confirm my current cooler is 2 inch and on the bell housing.
I think I will need a 3 x 18. Looks like around 3-400.00 bucks thanks for the inputs. Found lots of data from searching and will check mr. Cool. So far eddiemarine is the price leader.
knockld is offline
Old 06-16-2010 | 02:06 PM
I went thru the same issues. I posted on the other link.
whoya is offline
Old 06-11-2013 | 10:10 PM
bump
brianelectronics is offline
