Hydromotive Q-IV 22P L >
Old 06-14-2010 | 01:34 PM
Default Hydromotive Q-IV 22P L
Hydromotive Q-IV 22P left hand rotation. Excellent condition.
$150 plus shipping.
Can get pictures shortly.
Holy Smokes is offline
Old 06-14-2010 | 02:04 PM
Is this off of a Bravo 1? I'm running a 23P right hand mirage plus on my 27 fever. Just wondering what I will have to do if I go with a lefty?
Thunderstruck27 is offline
Old 06-14-2010 | 02:27 PM
Yes. I should have mentioned that it is for a Bravo 1, Alpha and TRS 15-spline prop shaft.
I've seen several Fountain singles with LH props. I tried a different Q-IV on a prior boat and experienced great transom lift almost to the point of bow steer. Didn't work for that app, but check with the Fountain crowd to see what their results have been.
I understand that a Bravo's direction can be changed just by the shift cable.
Old 06-15-2010 | 06:30 AM
I'll check to see what kind of mods are needed and hopefully get back to you before the prop is gone. If possible, please send a pic to [email protected]
tks
Old 06-16-2010 | 11:15 AM
Well...I found out that I may be under propped with my 23P Mirage, but the Left rotation should work better on my '94 fever. I think I'm going to look for a 24P Hydro quad. Good luck on selling your prop.
Old 06-16-2010 | 11:29 AM
What kind of WOT RPM's are you getting with the 23P Mirage?
and
What engine package?
You'll want to step down a pitch when going with a 4-blade vs. 3-blade.
Old 06-17-2010 | 08:51 AM
I running a 502 mag with carb (Holly 4150) and it runs pretty strong. .I just recently bought the fever and the tach isn't giving me very consistent readings so I don't have a solid reading on my WOT. I'm getting a quote for all new livorsie gauges but that's a winter project. The main reason I was changing blades was to conteract my starboard list without dragging my starboard tab. Now I think I'll just put up with it until after my dash mod.
Old 06-17-2010 | 09:20 AM
I think you're in the right range. 22 or 24 would be a good place to start. Years ago I had a Baja 240 with a 502 Mag and I tried a 23P Hydro QIV. For that boat it was over-propped and caused a slight bow steer. For the added weight and length for your boat, I think a 22P would be where I would start. I'm obviously trying to push my 22 but, I hope you find what you need.
If you want, buy this prop, try it out and if it doesn't work, just send it back undamaged and will gladly refund your money. It costs you just shipping cost each way.
Old 06-17-2010 | 09:56 AM
Thats a deal I can't refuse... Get me a total price and email a pic and your address to jamesmcd at tds dot net and send you a check.
Old 06-17-2010 | 11:21 AM
Email sent.
