Special relay for engine hatch actuator??? >
Old 06-14-2010 | 09:36 PM
Default Special relay for engine hatch actuator???
My engine hatch actuator has never been strong enough to get the hatch up in the closed position. I ran wires straight off one battery with me in the engine bay with the hatch shut and it went right up with no problem. So how can I get the voltage up with the factory switch? I don't see how I can a relay up because the positive and negitive wire is going to switch back in forth depending on which way you work the switch. I don't really want one switch to go up and one to go down. Is there a special relay for this?
chuckyarus is offline
Old 06-14-2010 | 10:00 PM
you will need 2 bosch 40 amp relay's follow this wireing exactly the way i give it to you and you wont end up with smoke..
turn the relay up side down and you will see numbers next to the spades coming off of them..
relay 1 # 85 & 87 loop the spades and tie them together,this wire will go to the + fused side of the battery..
# 87 a center spade will go to - or ground....
# 86 will go to your up or down switch
# 30 will go to one of the wires on the accuator..
Relay # 2 follow the same diagram,you can loop all the 85's and 87's together(power),,,you can do the same with the 87a's(ground)..
thease relays will reverse power and ground at the accuator..
disconnect the the ground wire going to the switch and everything will work fine..
FIXX is offline
Old 06-14-2010 | 10:05 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Make one for a few bucks from 2 relays from Radio Shack or AutoZone. You will still want to use heavier wires for the power leads. The switch leads don't need to be heavy.
I think I've read were you can buy this as a prewired system from Summit or such for $20-30?????
US1 Fountain is offline
Old 06-14-2010 | 10:26 PM
Ted G's Avatar
Here ya go, Hardin Marine calls the "Hatch Accelerators"
http://www.hardin-marine.com/SearchR...oryID~190.aspx
www.cbpba.com
Ted G is offline
Old 06-14-2010 | 10:39 PM
Ginger or Mary Ann?
$9
http://www.summitracing.com/parts/VI...5&autoview=sku
Old 06-14-2010 | 10:56 PM
Strip Poker 388's Avatar
Rob
sumitt sure is cheaper
Attached Thumbnails Special relay for engine hatch actuator???-hatch-acellorator-7-06-002-medium-.jpg   Special relay for engine hatch actuator???-ingi-switch-5-19-2008-056-large-.jpg
Strip Poker 388 is offline
Old 06-15-2010 | 01:54 AM
ballon78's Avatar
just did this mod myself a few weeks ago, works great. Went to Pep boys bought alarm dual relay harness in radio section for 10 bucks. Then go to Radio shack and but a 5buck project box, stuff the relays in side and your done!! Looks lake hardins bit for 15 bucks
96 HUSTLER 32, Vacuumed bagged layup, composite transom Blueprinted 502EFI's Mayfair, Dry-exhaust
ballon78 is offline
Old 06-15-2010 | 08:28 AM
I dont have a relay on mine and it works just fine. You are probably running to small gauge of wire. I have #10 on my hatch ram.
bobsbillets is offline
Old 06-15-2010 | 08:58 AM
Set it up with the relays. I did it and it works great! The only difference is I used sealed weather tight relays for snowmobiles. They were a little pricey but worth it. At least I thought so.
jmrapp is offline
Old 06-17-2010 | 07:46 PM
Thumbs up
works like I charm. Thanks Everyone and thanks for the wiring diagram. Thats why I'm on OSO!!!
