K K Tab Cables???
Just wondering if there are special cables that are used for KK Trim Tabs. The backing place has the cable mount/nut that appears to tighten and seal around the cable but just want to make sure that a regular good quality 3300 series cable would work.
Thanks,
John
Good to be back. Been out with a bad staph infection that kind of set my project back among many other things.
Thanks,
John
A regular 33C cable works. I like to use the Ultraflex cables, but any others will work. As you tighten down on the nut, it pushes the plastic piece into the rubber which then tightens around the outer sheath of the cable.
Eddie
Eddie
