Head bolt sealer? >
Head bolt sealer?
Head bolt sealer?
Old 04-29-2002 | 04:08 PM
Dave Schumacher
Default Head bolt sealer?
I am rebuilding my SBC and noticed sealer on some of the head bolts when I removed them. Does there need to be a sealer applied when reassembling and if so what should I used. The motor will be stock.
Old 04-29-2002 | 04:39 PM
Tinkerer's Avatar
Cool
A good quality pipe dope always worked for me.
Tinkerer is offline
Old 04-29-2002 | 04:42 PM
Whiteknuckle's Avatar
ARP sells sealer under their name. However it is really Locktite PST. Don't scrimp on this seemingly minor item. Use good stuff.
Whiteknuckle is offline
Old 04-29-2002 | 05:15 PM
blue thunder's Avatar
I've been using #2 permatex for years. If you use it ( or anything) on one bolt, use it on all of them equally.
BT
blue thunder is offline
Old 04-29-2002 | 06:43 PM
Crazyhorse's Avatar
I've been using Chem-Tec red high temp RTV after having leakage around the head studs on one of Dyno's engines. Used Permatex the first time around.
Crazyhorse is offline
Old 04-29-2002 | 07:09 PM
Crazyhorse... are you saying the #2 permatex failed to seal the threads and the only change you made was to RTV then all was well? How long did the permatex take to start leaking? This is not good new too me, so some substantiating detail would be appreciated.
BT
Old 04-29-2002 | 07:19 PM
The last time I did mine I tried permatex hylomar. I don't know how this will work out. Hylomar (I think that is how it is spelled) was made by rolls royce to seal their jet motors. It is a non hardening sealer.
Has any one else tried this stuff???
FlyFast is offline
Old 04-29-2002 | 07:20 PM
Ihave always used Permatex #2 and never had a problem.
TomR is offline
Old 04-29-2002 | 08:59 PM
Crazyhorse's Avatar
Dyno had a cylinder head stud kit that he wanted to use on one of his engines and after using Permatex on the studs the water seeped out of the fine threads above the nuts and washers. I will say this- I've never had any kind of leakage issue with stock or aftermarket cylinder head bolts, and up until recently, I never used any sealer on the threads. I lubricated the threads and torqued the head bolts.
Old 04-29-2002 | 11:24 PM
Use a small amount of teflon thread sealer on all the bolts or studs and you will be fine.
fstboater is offline
