94 208 Islander Any Info? Thanks Guys
I recently picked up a 1994 Islander with a 454 and bravo 1 outdrive. It has a Mirage 23P prop. Is that a good choice? The 2 guys that owned it!! Didn't know much about it other then it was a boat and was fun. This is my first boat of any size always had little runabouts. Guess this is too compared to some of you guys!!! Anything to look out for? Any parts to put on it, I am the guy that puts the extra on if it is needed or will save me in the long run. Not looking to be the fastest but not the slowest either. Thanks for any and all comments. Any questions you have please ask I will answer to the best of my knowledge for any good advice.
i know its long after your question but i have a 208 islander with 310hp 454 and a bravo 1 with 1.36 gear and it spins a 20p 4 blade stilletto to 4800 and 61 on gps but i am at 5000ft so i would bet a inch or two would do you better than me that 23 sounds pretty good for a 3 blade my boss has one on a checkmate and he cant out run me baja's run fast with good prop and just a little trim man
23 mirage is what my boat came with, If i remember right, 66gps was the best I ever got out of it stock. Light load on a cool day. Upgraded to 30 over 454 with better heads and cam with gils exhust AND added M1 procharger it will hit 80 everyday anyway best was 83.6 gps. Very fun boat that is why I still have to wake board .
ok guys especially A.O. seems real familiar with my boat so once i get it settled down and hopefully huffer goes on it looking about 100 more hp what kinda prop change would i be looking at? i would like to run a 24p bravo 1 prop i have been impressed with this 4 blades holeshot and cornering it even helped the porpoising some its not real big though 14 in 20 pitch on 1.36 bravo drive
Regarding your porpoising, what I'm thinking is either a hook, or a prop that won't carry the bow. I don't have much experience with your current prop, so won't go into that. I've been in 208s with SBCs and BBCs and they did not have a porpoise issue. That is why I belive you could fix it. Check your bottom and spend some time testing a 21" Vensura and Rev4. Going to a Rev4 will probably put you around 4500 if you are currently spinning 4800 with the 14"x20" and the Vensura a bit more.
Bblades have a test program where you can try props for 45$ in 15 days. He is also very good when it comes to labbing the Mirage+ for the Bajas. Either way, it's money well spent.
Take one thing at the time. Make it run right first and worry about the new prop pitch when you add the power later.
this question is for procharged 454. The boat you have just built is exactly what I am going to try to build. I used to have a 95 Baja 208 with a 23Mirage prop and it would do 64 all day with two person and half a tank of gas. This was the 330 hp 454 motor.
Recently found one without a motor so wanting to restore and build a blown big block. I have a 502 injection system with a procharger M1 setup. Not sure if I will go 454 mag route or the 502 route. I am interested to see what cam, what boost, and the exact prop you are running on your boat. Please let me know. Thanks
I don't want to hijack this thread but does anybody by any chance have the hand held shower mounted in the swim platform, or the Colmen electric cooler heater specialy design to fit underneather the passenger side console?These were options from the factory on the 208 islander. Mine doesn't have either but I want to add both to mine, I'm just looking for a picture of these options so I can imitate the factory install.
