How to tap 502mpi fuel rail?
I am upgrading my 97 501mpi/whipple fuel system to eliminate the stock fuel system and whipple. I am going to use an aeromotive a1000 fuel pump and boost referenced regulator. I have searched and found good information and I want to tap the fuel rail, but have not seen any detailed instructions, so I have questions! Maybe it is straight forward once I start, but any tips would be helpfull!
What size? 3/8 NPT to -8an
What type of tap? male pipe tap.
Do you need to drill it? If so what size drill bit.
Procedure to unshroud #7 injector. Once again maybe straight forward
What about the return line port that will no longer be needed.
Tap and plug it?
Is there room to tap both ports side-by-side?
What sealer for pipe threads? thread tape, pipe dope
Thanks for any help you can give me. Rockie
Tap and plug it?
