need advice on prop for 2006 baja 25 outlaw hitting rev limit
well i just picked up a 2006 baja 25 outlaw took it out and it comes out of the hole quick compared to my h2x. but at about 66-67 on speedo it hits 5400 rpm and alarm goes off. it is full of gas 90 gallons at least. with three people. i thought it felt a little slower than my h2x. it has the same prop as my h2x
23p mirage plus 3 blade
496 ho 425 hp
bravo x 1.50
i would like more top end if possible. also 4 blade if this could go together.
whats the stock prop supposed to be?
496 ho 425 hp
bravo x 1.50
Most of the 25 OL settle on a 4 blade of some kind, usually B1. It works well overall especially preventing blowout while turning. Mid range cruise picks up considerably and you might see just a bit more speed on the top end. If you are turning a 23 mirage that hasn't been touched to 5400 RPM you have a really strong 496HO. Get a bigger wheel. If memory serves me correct you will drop 200 RPM for each inch of pitch.
It's all about what you like the feel of. My 25 blows out the 3-Blade, slip is way high hard to keep it on plane under 3000RPM and then doesn't want to take off from there without blowing out. I would try a 24P B1 to see if you like or even a 26P B1.
I agree with talking to Bblades plus he has a loaner program.
