Imco standard lower vs XR lower >
Old 06-20-2010 | 08:06 AM
Default Imco standard lower vs XR lower
Assuming we are comparing standard lenghts, what type of speeds are gained by going with an Imco Standard lower instead of a standard XR lower?
Boomer35 is offline
Old 06-20-2010 | 08:11 AM
Using the same gear ratio and prop, NONE.
Rattlesnake Jake is offline
Old 06-20-2010 | 11:00 AM
If you ar over 80mph, then you might see a small gain from the Imco nosecone design.
Griff is offline
Old 06-20-2010 | 12:14 PM
CB-BLR's Avatar
Chris
I have found a 1-2 mph difference between the standard XR lower and an IMCO lower on a couple of boats, both doing around 80 mph at the time.
At 90, the difference was drastic in both speed and handeling .. 4 mph, and a much more stable ride with the IMCO on my Heat.
Slip went down, speed went up.. handeling was better.
Just my observations,
Chris
CB-BLR is offline
Old 06-20-2010 | 02:26 PM
+1 for 4 MPH above 90 with twins vs. XR
BenPerfected is offline
