Go Back  Offshoreonly.com > Owners Forum > Sunsation
sea water impeller change 25 agressor >
Old 06-21-2010 | 02:59 PM
Default sea water impeller change 25 agressor
how do you get to the pump to change the impeller on the 1998 25 agressor 454 mpi it is way down under where you can barley see it.
rssteiny is offline
Old 06-21-2010 | 05:27 PM
You have to pull the entire backseat out.
atthelake27 is offline
Old 06-21-2010 | 07:02 PM
Looks Like You Need To Lift The Motor, Have You Done It With The Back Seat Out, Is It Still Hard To Get To Or Not So Bad With Seat Out.
rssteiny is offline
Old 06-21-2010 | 08:57 PM
Once the backseat is out your good to go. There is a couple bolts holding it to the floor and a couple on each side. Done it many times.
