Low RPM's
Old 06-21-2010 | 03:04 PM
Default Low RPM's
Does anyone know what a OMC 305 should be turning for top rpm's? I have a 21 pitch stainless prop and its only turning 4000 wide open... Seems way too low. Anyone have any input? Thanks
Browny0386 is offline
Old 06-26-2010 | 08:37 PM
You didn't give any boat details. However, if you don't have the manual for your boat, I believe the max rpm is 4400-4600.
Hollowpoint is offline
Old 06-27-2010 | 06:57 AM
check to make sure your throttle blades (carb blades) are opening fully. Look down the bores...they should be straight up and down. Whens the last time it had a COMPLETE tune-up ?
tinman565 is offline
