27 Glasstream is running bow down and slow I could uses help >
Old 06-24-2010 | 08:39 AM
Default 27 Glasstream is running bow down and slow I could uses help
I have a 27 glasstream I bought through insurance it was completely stripped origanally had 1 engine. I have rebuilt boat with two 250 efi Yamahas and can only get it up to 58 mph at 5400. I have put nose cones on it with low water pick ups and manual jack plates. I am running 25 miriage props with a countrer. I am not sure what side the counter should be on I have tried it both ways to try and get bow lift I am not sure about what style of prop I should run or what heigth I sould be. I here of big mph numbers out of these boats but I am not even in the ball park.
Total Rec is offline
Old 06-24-2010 | 08:44 AM
Spin the props in for bow lift, maybe 4 blades?
showtime83 is offline
Old 06-24-2010 | 11:10 AM
Try corking the front live well. It will fill and not drain. Is it a scx or ccx? Also that boat loves bravos or power tec 4 blades.
SVL-WARLOCK is offline
Old 06-24-2010 | 11:25 AM
It is a scx will 4 blade give me bow lift?
Old 06-24-2010 | 11:56 AM
Usually they offer stern lift. That boat just loves 4 blades for some reason. Never had any luck with 3 blades on that boat at all.
Old 06-24-2010 | 03:17 PM
What pitch should I start with?
Old 06-24-2010 | 03:47 PM
those motors turn around 5750 or so. i wold see if i could try a 24 or 26. you might call power tec and see what they recomend. Also either size bravo. try and find a dealer with blue ones. They are the loaners.
Old 06-24-2010 | 08:58 PM
I was on one last weekend w/ 225 optis, I think he is getting close mid to upper 70's the thing takes off like a rocket. definitely running 4 blades not sure on the pitch, it's a light boat and it was rough so we took a beating
this was an 04 scx
Pete280 is offline
Old 06-25-2010 | 05:36 AM
Pete280 Any issues with the o4 boat ? I'm interested in the boat, but not many made so information is scketchy
James is offline
Old 06-25-2010 | 07:53 PM
I thought it was a decent boat, definitely not made for rough water, we came back from the eastern shore in honest 3-4's and it was brutal. If you up on the James or somewhere protected I think it's a good boat. With 225's it flew,
btw, it seemed to run flat to bow down, but that was probably due to the seas
Pete280 is offline
