rpm
not sure if any thing is rong but i cant get my rpms over 4200 wide open and trimed out i was told it should turn more like somewere in the 4800-5200 its a stock 7.4 (454) mpi with stanless marine exhaust is that true
I think your motor has a 4200-4600 operating range.
So you wouldnt be to far off.
You can drop a couple inches of pitch to get it higher.
Generally speaking for a pleasure boat, on a cool day no gear, no fuel, 1 or 2 people you should be right at the high side of the rpm range.
If all your covers are intact on the motor, the operation range will be right there on a sticker
I want to live in a world where a chicken can cross the road and not have its motives questioned.
23p , Can i reprogram the computer to get higher rpm or will that mess the motor up if you can even do that. i feel like the boat should be faster, and it has truble planeing out but the motor sound great. oi was thinking the boat sould run around high 60s maybe 70 stock
Is your boat a Baja 240?
For referance my 1997 turns a 23P Mirage Plus at 4700-5000 with the 7.4L carb and runs 63.5 on GPS tops. The differance depends on water conditions and where I can trim to.
One would think the MPI would out perfom this. Have you verified the speed with GPS? You could also verify your Tach reading as well.
I should add my numbers were lower when I first took the boat out after buying it this spring, I contribute that to the storage time of the gas (18mo). The first time I filled it with fresh 93 after runnig it empty the numbers came up considerably.
I have a 24P Ballistic XL i am going to try this weekend and will post you the results.
23P Mirage is what i am running to but my boat is a 88 226 sport, the one in my profile pic, i hear there the same as the 240 outlaw kind of any way, i have had people tell me it should run around 70 easy with the 7.4 mpi. I need to gps it but it doesnt feel like it runs that fast im going to try a 21p 4 blade this weekend to see if it gets on plane faster (let me know how that 24P Ballistic works out for you.)
well i tryed the 21p 4bl/ came out the hole a little better until i had 5 people in the boat then i had to get 2 of them in the front so it would plane out and i did find out that my rev limiter kicks in at about 45-4800 but i can only hit that if i rev it out of gear maybe my boat is ment to be slow
i hope not.
i hope not.
21 4 bl isnt must different then a 23 3 bl load wise.
Try a 21 3 bl mirage plus and I think you will be there
