Stainless Marine Short tube Alum Headers >
Old 06-24-2010 | 01:51 PM
Default Stainless Marine Short tube Alum Headers
These are great headers for upwards of 700hp (I’m told). True equal length short runners, and dry exhaust tubes (up to the transom), make these great for an application like I had (~600hp 502) where I didn’t want to spend $4k on headers.
They should exit out a stock Bravo Transom cutout, are light weight (aluminum) and have never seen salt water! By opening or closing water exits at the end of the pipes, they can be adjusted all the way from full wet to full dry.
Both stainless exhaust tubes have had adapters welded in for wide range O2 sensors. The placement works great and the sensors stayed alive for many weeks of use.
They have an amazining anodized red dual stage powder coat that is impervious to fuel.
The entire setup is included:
Tail Pipes
Clamps
Stainless Transom Plates and rubber gaskets
New Exhaust gaskets.
External Flappers
$995
[email protected]
PLEASE email me as I may not see replys here.
Attached Thumbnails Stainless Marine Short tube Alum Headers-exh.jpg   Stainless Marine Short tube Alum Headers-eng3.jpg
bcarpman is offline
Old 06-24-2010 | 03:15 PM
Could use some measurements.I had 3"spacers on my stock setup.Thanks,Bob
Cookin is offline
Old 07-24-2010 | 11:24 AM
Ok, lowered it to $995. That's as low as it goes. If they don't sell I'll just hang onto them
bcarpman is offline
Old 07-25-2010 | 06:50 PM
Those are identical to mine,
I dont think they are Stainless marine though they are Drakes
at least mine are Drakes, work very well.
http://www.offshoreonly.com/forums/g...t-headers.html
http://www.offshoreonly.com/forums/a...s-p1000248.jpg
HTRDLNCN is offline
Old 07-26-2010 | 11:09 AM
Email Sent
Ghostrider is offline
Old 07-26-2010 | 02:42 PM
Thanks for the info. The only name on them is on the tail pipes and that says Stainless Marine, so that's what I thought they were.
bcarpman is offline
Old 07-26-2010 | 08:11 PM
ENFORCER24's Avatar
I'm scrapping my bucks together if there still available
ENFORCER24 is offline
