New 525 efi overheating >
Old 06-26-2010 | 07:26 PM
Default New 525 efi overheating
I have a new eliminator speedster with twin 525 efis. At 5250 rpm the engine is warming up past 190 and going into guardian. My water pressure doesn't get over 24 psi. Is this the problem. Manual says 20 min 40 psi max. Thinking about spacer for drive. Any suggestions
rsess is offline
Old 06-26-2010 | 10:05 PM
Mine preasure is around 30psi or a little better, make sure its not plugged by a little stick or debrise
firehawkcat is offline
Old 06-27-2010 | 10:37 AM
Anybody know a reasonable temperature for running at 5000
rsess is offline
Old 06-27-2010 | 11:28 AM
Default Fixx
Drive height or your impeller is on its way out.. look at the bottom of the drive and look for cavitation burns,if theirs some present then your drive may be to high
FIXX is offline
