Boat pulling to left >
Old 06-27-2010 | 07:21 PM
Default Boat pulling to left
Just purchased a 2000 Formula Fastech 312 twin 454s bravo drives, boat pulls hard to left at cruise (40mph) when you release steering wheel. Any idea why? (new to twins).
fastech312 is offline
Old 06-27-2010 | 07:37 PM
Von Bongo's Avatar
I had a boat that did that at one time. It had a small leak in the Hydraulic steering. When that was fixed no more problems.
If you have cable steering, maybe check the tow.
Von Bongo is offline
Old 06-27-2010 | 08:50 PM
seafordguy's Avatar
I assume your drives are rotating in opposite directions and you consequently have left and right rotation props on it correct?
seafordguy is offline
Old 06-28-2010 | 05:59 AM
yes, check the drive toe setting, ext steering ? if not the p/s control valve could be bad as well...
ezstriper is offline
