Bravo 3 Question
Old 06-30-2010 | 05:50 PM
wantsa311's Avatar
Default Bravo 3 Question
I'm looking at a Formula PC 34 that has Bravo 3 outdrives. Strange thing is both lower units say Bravo 3 on them but they are noticably different. The uppers look to be the same. Obviously one of the lowers has ben replaced - were there a couple of generations of Bravo 3's?
wantsa311 is offline
Old 06-30-2010 | 09:18 PM
Mr Gadgets's Avatar
Charter Member #601
There is a Bravo 2 that has a much shorter case with the dual prop than the B3. Any pics?
Mr Gadgets is offline
Old 07-02-2010 | 07:33 AM
hoozeyurdaddy's Avatar
They made a B2 dualprop? I have never seen one, all the B2's I have seen just had the large dia. single prop. Do you have any pic's of one?
hoozeyurdaddy is offline
Old 07-02-2010 | 07:43 AM
Knot 4 Me's Avatar
What year is the boat? The early Bravo III's (mid-90's) had a 2 piece cavitation plate. That is the only real significant difference in years other than the addition of a second zinc over the aft prop and a bullet-zinc on the prop shaft. The only other dual-prop lower Merc had was the Blackhawk. That lower would have been significantly shorter and more swept-back.
Edit. 2005 and newer Bravo uppers have the new swept back design due to changes in how they shift. But you said the uppers look identical so...
Knot 4 Me is offline
Old 07-02-2010 | 07:45 AM
Ted G's Avatar
There is a Bravo 3 XR, which they use on bigger boats now, maybe someone switched over one after the failure. That boat has to be hard on drives.
www.cbpba.com
Ted G is offline
Old 07-02-2010 | 07:47 AM
Knot 4 Me's Avatar
A dual-prop Bravo II? Interesting. I've never seen one. Learn something new every day!
Old 07-02-2010 | 07:52 AM
Knot 4 Me's Avatar
Externally, I don't think you can tell a difference between a Bravo III, Bravo III X, and a Bravo III XR other than the stickers and the props used on the XR's. Now even the standard and X have the 4-blade/3-blade prop set. But they are not the same as the XR props.
Old 07-03-2010 | 10:48 AM
wantsa311's Avatar
Both units say Bravo III on them. See how the port cavitation plate is pretty much flat across the surface where it mounts to the upper? The starboard side has a raised portion that blends with the ridge on the upper, looks like it might be for reinforcement.
Old 07-03-2010 | 06:26 PM
Mr Gadgets's Avatar
Charter Member #601
Oh oh.. you guys called me on that one and I will admit!! I was wrong. Not sure what I was thinking. I know the B2 had a fat bullet. Not sure why I was thinking dual prop.
Maybe it is the lack of sleep and old age catching up with me!!
You guys are correct. The B2 was a single prop.. My Bad!
Not sure what you have there. Looks like someone added something to the tail of the upper??
I have only worked on a couple of B3's and no B2's..
I promise to be more careful with my outbursts of ignorance..
Dick
Old 07-03-2010 | 10:04 PM
wantsa311's Avatar
No worries, I appreciate you reading my post. Check out this diagram, supposedly for a Bravo III, looks just like the starboard drive. Part number 11. What the heck is this thing?
http://www.perfprotech.com/store/ass...),952-110.aspx
