496HO Oil Pressure
Hey Guys:
My 26 Outlaw (496HO) typically runs about 40 PSI of oil pressure at idle and close to 60 PSI at higher RPM's (above 4000). Recently I noticed that after I run the boat at higher RPMs (4500) for a period of time when I pull back to idle the oil pressure falls to around 20 PSI. It will slowly creep back up to 30 - 40 after 10 minutes or so at idle. Is this a concern or problem ?
I am using Mercury 25W-40 synthetic blend oil with the Mercury oil filter. There is about 20 hours on the oil since its last oil change.
Thanks,
Steve
Thanks,
Steve
When the oil gets hot it thins out. The pressure comes back when the oil cools down. As long as your minimum pressure is above 10 psi at idle, you will be fine. Just be sure to do frequent oil changes and use good oil.
Hey Guys:
Thanks,
Steve
Thanks,
Steve
