Bravo One trim ram rubber bushings... upgrade? Urethane? >
Old 07-04-2010 | 08:19 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Default Bravo One trim ram rubber bushings... upgrade? Urethane?
It's time to replace mine as I can see what I call excessive movement in the rubber.
Is there an upgrade or better material for these parts that anyone makes or can recommend?
Thanks in advance.
Sydwayz is offline
Old 07-08-2010 | 03:21 PM
I purchased some upgraded ones a while back, I think it was from Harden Marine. If you need me to check for you I can. I also just purchased a bravo HP transom assembly and it has urathane bushings on it that I didn't use. I had already purchased the red Harden bushings so I used them.
doutlaw25 is offline
Old 07-09-2010 | 01:56 PM
Wobble's Avatar
SORE MEMBER
These ones?
Good find
http://www.hardin-marine.com/SearchR...oryID~231.aspx
Wobble is offline
