purchacing dry exhaust >
Old 07-05-2010 | 08:47 PM
Default purchacing dry exhaust
what companys make dry exhaust? what do they start out price wise
mookster is offline
Old 07-06-2010 | 12:16 AM
Pretty much any exhaust manufacturer (CMI, Stellings, IMCO, Dana, Eddie Marine, Stainless Marine, etc.) will make dry tails for you. Just the tails, or risers on a manifold setup, will start about $1000 and go up from there depending on complexity. That is just for the tails or risers. That does not include the price of the headers, or manifolds. You could spend as little as about $2500 for manifolds and dry risers in a simple setup to well over 10K for big tube headers and dry tails. What do you have (boat and engine), what are you after, and what is your budget???
Eddie
Young Performance is offline
Old 07-06-2010 | 06:33 AM
From a reliability standpoint as ease to deal with , I am a big fan of Stainless Marine. Depending on your engines you may give up some power with the Stainless stuff but it sure last long!
Steve
smiklos@sunprint is offline
Old 07-06-2010 | 08:18 AM
550hp motors with bw trans and trs drives..
really like the look of the lighting headers but would like a dry setup.. like the tube header style
mookster is offline
Old 07-06-2010 | 10:20 AM
You can have a new tubular style header setup without being dry to the tips. The tails will be jacketed, but you can still introduce the water into the exhaust. I'm sure you know, but a completely dry exhaust(meaning the exhaust and water never mix) is VERY loud.
Eddie
Old 07-06-2010 | 10:59 AM
Too Stroked's Avatar
Eddie
I was just going to add that point. How loud are they? Your dentist will be seeing you more often to replace fillings that were rattled out. A friend of mine had an old 10 meter (33') Fountain with dry pipes a number of years ago. You literally wanted to jump overboard after about 10 minutes. It's unbearable.
Too Stroked is offline
Old 07-06-2010 | 11:35 AM
what would be the cheaper price on a tubular header dry system????
mookster is offline
Old 07-06-2010 | 02:21 PM
If those dry pipes are too much for someone I'll take'em off ya and put them in my boat..
What size and how much for the tails?
SDFever is offline
Old 07-06-2010 | 04:54 PM
since water isnt going to exit the tails were will the exiting water leave with a dry exhaust?
mookster is offline
Old 07-06-2010 | 06:27 PM
Rookie's Avatar
Here is my Stainless Marine TRS dry exhaust, it is dry to the tips. Water exits out the 1" pipe.
Rookie is offline
