Gas mixed with Race Fuel ? >
Old 07-06-2010 | 02:46 PM
Default Gas mixed with Race Fuel ?
My marina only has enthonal free 90oct and I can get 102oct race fuel ,just trying to do the math and want to come up with the correct mix to make 93oct gas. So 1 gallon of 90oct to ? 102oct.
boating37 is offline
Old 07-06-2010 | 02:54 PM
Here ya go
http://ranney.com/mjr/fuel_blend.html
apache727 is offline
Old 07-06-2010 | 03:00 PM
BY U BOY's Avatar
http://members.cox.net/ftraycing/octanecalc.shtml
BY U BOY is offline
Old 07-06-2010 | 03:02 PM
to get to 93 octane, use 25 gallons of 102 for every 75 gallons of 90
waterboy222 is offline
Ok got it, Thank you.....
Old 07-06-2010 | 03:10 PM
If I did the math right, 3 gal of 102 + 7 gal of 90 = 93.6
BenPerfected is offline
Old 07-06-2010 | 03:14 PM
Is the 102 a bulk tank fuel or is it 55gal drum qty? If it is, might check with the supplier and find out the specific gravity of the 102. If its a branded fuel like "turbo blue" or something, it may be a little lower SG than the 90. It will initially mix up just fine for about 7-10 days then will definately stratify (seperate layers)...
Not an expert, just a chemical blender familiar with SG's and blending..
Old 07-06-2010 | 03:30 PM
Bullhead's Avatar
If your engine is designed to run on 93 octane and you mixed the fuel and ended up with a higher octane say like 95 or 96could it actually hurt anything?.....would it hamper performance?
Bullhead is online now
Old 07-06-2010 | 03:31 PM
I was just going to pick it up from Sunco station and fill a big 20 gallon fuel tank up and the put the 90octain in at the marine.
Old 07-06-2010 | 03:45 PM
Call down to the station and find the name of the fuel. Sunoco lists all their SG's in PDF form..
