led light not working when operating turn signal >
Old 07-06-2010 | 09:06 PM
Default led light not working when operating turn signal
Light comes on when turning on parking or headlights.All bulbs are burning but want blink when turn signal is engaged.Truck lights works fine and power is coming through plug end.Any ideas why trailer light isn't blinking??
Hank36 is offline
Old 07-07-2010 | 08:53 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Is it a two stage light with three wires coming out of it?
Can you take a multimeter and check the voltage when the signal is on?
Does the other side work?
Does it work when the flashers are on?
Sydwayz is offline
Old 07-09-2010 | 08:45 PM
Registered User
some leds dont draw enough to flash, have to get a different flasher sometimes
CSCinc is offline
Old 07-15-2010 | 08:26 PM
sounds like a bad groud, same thing happened to me.
Flapjack is offline
Old 07-16-2010 | 09:46 AM
Wally's Avatar
Were doomed!
dos it get brighter when you hit the brakes? if not then that leg of the circuit is not working. It will be the green and yellow wires. They do brake lights and turn signals....check there...and as CSCinc mentioned some LED's dont have the proper resistance to trigger the flasher the proper way and will give you a signal of a fast blinker like you have a bulb burnt out...you would need to switch the flasher relay.
-Wally
Wally is offline
