stuck engine hatch on 32 fountain fever >
Old 07-06-2010 | 10:54 PM
Default stuck engine hatch on 32 fountain fever
my engine hatch is stuck shut. motor makes a ratching sound when you try to open it similar to what it made when it was fully closed. i took the hinge pins out and can't access it from that side either. any ideas?
SLPREROX is offline
Old 07-07-2010 | 08:07 AM
Too Stroked's Avatar
Have you tried pulling the hatch up / open while somebody else holds the switch? That will generally get a power hatch open enough to pull the pin.
Too Stroked is offline
Old 07-07-2010 | 04:28 PM
it just keeps on clicking. I even trie taking the hing pins out and doing it from that end, no change... thanks for the reply!
SLPREROX is offline
Old 07-08-2010 | 09:16 AM
check your main fuse off the battery selector. might be alittle corrosion going on there. thats what happened to mine last year. made me crazy until i found that was the issue.... mark
mookymonkey is offline
Old 07-08-2010 | 03:32 PM
if you cant get it open you will have to axes the bolt that holds the ram to the hatch threw the side vents. good luck
brians fever is offline
Old 07-08-2010 | 03:42 PM
Ah, anybody with at leat a 48" sleeve ought to be able to reach that!
