Go Back  Offshoreonly.com > Owners Forum > Black Thunder
Shower drain issues >
Shower drain issues
Shower drain issues
Old 07-07-2010 | 08:05 PM
Default Shower drain issues
My Fellow Black Thunder owners,
I have a bit of a issue with my shower drain not pumping out. The pump is running but the water does not drain out of the floor, what could be the problem???
I made a small attempt to make sure it was not clogged up. It smells something awful!!
Eric.
97 43 SC.
Nevr2nd is offline
Old 07-08-2010 | 09:14 AM
Sounds clogged. Maybe let some water and possibly drano or something like that set in it for a few mins. Maybe take an air compressor and try and blow it out. If it smells, it probably is clogged. Good luck.
THLWL is offline
Old 07-08-2010 | 05:38 PM
okay thank you
Nevr2nd is offline
