trailer jerks when taking off
have a triple axle trailer with 2 axles that have drum brakes (surge brakes) when i stop fairly hard the trailer slams and when i take off from a light even very slow i pull it 4inches hen it jerks hard then starts moving. whats the deal brakes not working?
4 inches seems like a lot which could be that the brakes need bleeding and or adjusting or replacing. Mine will move maybe 2" and after a hard stop it will jerk the tongue forward before trailer actually moves.
Check your fluid level first. Could be empty and if it is, that usually means you need to bleed them which is easy with two people.
Member of the Liquid Jungle
Drums are high maint on two axles. Just the slightest bit of wear and you need to adjust to keep from banging. Adjust them up snug and bleed to get all the air out of the system. They should not bang. Disc brakes don't have to adjust and are way less hassle.
Ann I take off I feel mine "catch" and when I come to a stop I also feel the trailer when the tongue slides forward. Not sure I would call it like a bang but I can feel what it's doing. Just had mine completely serviced by our local truck and trailer shop to. I thought this was somewhat normal????
In my experience, if you're feeling a lot of movement, either your brake shoes are not adjusted correctly or you have air in the lines. Since air is compressible and liquids are not, you get excess movement.
