install amp in engine bay compartment??? >
Old 07-13-2010 | 09:21 AM
Default install amp in engine bay compartment???
I have seen a couple boats with marine amps installed in the engine bay compartment. Has anyone else done this? I like the idea. I would rather not run 20' of power and ground wire to the cabin. However I am looking for thoughts and opinions on this.
hanzcap is offline
Old 07-13-2010 | 09:26 AM
Audiofn's Avatar
Charter Member #232
Personally I would try and avoid it. The engine bay can be wet, but is almost always hot. Heat is not an amps friend.
Put your best foot forward!
Audiofn is offline
Old 07-13-2010 | 09:29 AM
i wouldnt because of the heat....
theadamv1 is offline
Old 07-13-2010 | 09:35 AM
BDiggity's Avatar
i personally would run & did run 0g to the cabin.
but i have seen amps in the engine compartment & they seem to work fine.
BDiggity is offline
Old 07-13-2010 | 09:38 AM
I would avoid it. Some amps use relays, which would not be CG approved and could be very bad (ignition risk).
I ran mine using 2 ga jumper cable wire ($40 for 40' of wire). Just bought a set of cables and cut off the ends.
apollard is offline
Old 07-13-2010 | 11:04 AM
that is a good idea! Jumpers could easily handle the current flow and are way cheaper than wire by the foot. Shows how we get raped as consumers.
Fixxxer22 is offline
Old 07-13-2010 | 11:07 AM
Ok, so how about under the aft bench seat?
hanzcap is offline
Old 07-13-2010 | 11:16 AM
or go to attwoods and buy welding cable.. its a LOT more flexible and its cheap as can be.
waterboy222 is offline
Old 07-13-2010 | 11:31 AM
Under the back seat is a much better option. That is where I have my amps.
Griff is offline
Old 07-13-2010 | 12:11 PM
Thanks for the input Griff. Since I have a battery installed underneath the seat it seems to me to be the next most logical place to put it.
hanzcap is offline
