Need some ideas on building a 1990 7.4 330 hp >
Old 07-13-2010 | 08:34 PM
Default Need some ideas on building a 1990 7.4 330 hp
my buddy has a 1990 7.4L 330 hp, he was wondering what can he do as far as bolt on mods to give it a little more juice. any suggestions for cam, intake, heads, etc.. would be great
87MagnumII is offline
Old 07-13-2010 | 09:01 PM
The 330's had peanut port heads, cast internals, and wimpy cams. Not the greatest foundation for making power. However, a head upgrade, cam, roller rockers, intake and carb would wake it up big time.
MILD THUNDER is offline
Old 07-13-2010 | 09:39 PM
any suggestions on a cam kit and heads and intake? anything anybody has tried that is proven?
Old 07-15-2010 | 07:42 AM
Default Need some power...
BROWNIE RACING ENGINES-
Matthew Brownie, builds engines here in VA and knows his stuff!!! I have the same engine, only it's a '96 and we just talked a week ago about what we could do this winter to wake it up! If interested in talking to him, PM me and I will get you his info! This guy has factory reps calling "him" for advise. Great guy and a heck of an engine builder!
Famous Tater is offline
Old 07-16-2010 | 06:10 AM
try to find a set of 781 large oval port heads, a RPM air gap intake, good marine profile cam, either a 750 or 800 DP holley and should be mid 400's hp
ezstriper is offline
Old 07-16-2010 | 07:51 AM
really need to figure out where you want to be HP wise. I'd probably go with the cam that came stock in the 400 and 420 mercs. Its a crane cam. Edelbrock air gap intake, some roller rockers. If you have a quadrajet carb it can work on a mild build like a 400HP engine. You can always pick up some used rect port heads that came on the 365HP and up merc motors if your on a budget. Ovals would be a better choice, but not absolutley necessary. Keep the wot rpm 5k or under with the cast internals of the 330. Better exhaust manifolds sure wont hurt either.
