Power Steering Belt Jumping Off
Just recently did some performance upgrades to my Baja 250 ES, 454 BBC. One of them being doing away with water circulating pump and going with stainless marine water crossover kit. Ever since I did this, the power steering belt keeps jumping off. I have changed the belts out and it continues to jump off. I am assuming it is because it is such a long belt now (50"). It has to go from the power steering pump, all the way to the crank shaft pulley. Have any of you ever experienced this? I never had a problem with the belt jumping off when I ran the circulating pump. The pulleys are in line with each other. I was wondering if there is any type of tensioner assembly because of the belt being so long? Any suggestions?
The belt could be bad. Is it a new one or the same one you took off??
Otherwise it is just out of alignment. Check it with a straight edge, or a lazer, then shim the back of the pump until it lines up.
I would guess it would be one of two things. One, the pulley alignment problem as already mentioned. or two , the width of belt is to wide for the pulleys. This would cause the belt to ride higher in the v groove of the pulley than it should.
