1996 272 baja, will a 2272 boss windscreen fit?
I have a 1996 272 Baja and i don't like the look of my windshield, I have seen 272 bajas with the windscreen instead of the windshield will this fit mine as a direct replacement? and if so where can I get one?
Find some someone that has a 272 with a windscreen and ask them if you can make a cardboard template from theirs. Also, take plenty of pics. Then have a plastics fabricator make you one. Lots of options this way on color and/or material. Probably going to be about the only way to go.
Custom Interiors & More
I don't have good news on this one. Baja built one special deck mold to offer the windscreen option, and you most likely don't have a deck from that mold? Next problem is finding someone capable of making one, or finding one? The last 275, and 245 windscreens on GL Skipper are the only two that I know of that could be modified to fit. The curve of the center section would match the curve in the deck, but the side wings are much shorter that the 272 deck. Then you would have to create your own mounting system somehow?
XT
XT
XT
XT
I found a company in FL but you'll need to have a mold made. So you'll have to get someone to let you use they're windscreen to make the mold and your looking at between 2500-3000k
