change from thru hull to drive water pick-up, speed ? >
Old 07-15-2010 | 03:23 PM
Default change from thru hull to drive water pick-up, speed ?
somebody along the way installed a thru hull with a large bronze scoop/grate on my boat, no idea why, question is how much speed does that drag cost ? really considering going back thru std bravo drive ?? thanks Rob
ezstriper is offline
Old 07-15-2010 | 03:59 PM
It can be substantial.
Steve
smiklos@sunprint is offline
Old 07-16-2010 | 06:02 AM
Too Stroked's Avatar
Steve
Agreed, but depends on how fast you're going. At 70 MPH in your boat for instance, it's probably less than 1 MPH. At over 100 MPH, it gets more significant in a hurry.
Too Stroked is offline
Old 07-16-2010 | 07:05 AM
When I bought my Corsa it was a successful A class boat (Hog's Breath). We bolted a HP 500 in it winter of 1997 it went 73.4 MPH. We removed a pretty well done transom pickup and netted a 1.7 MPH increase. In the end the boat set the Kilo at 81.034 in Sarasota.
Sweat the little stuff!
Steve
Old 07-16-2010 | 07:06 AM
The water going through the drive also helps cool the gear oil.
Steve
