New Drive - break in ?
Old 07-16-2010 | 09:04 AM
Default New Drive - break in ?
New Drive going on my boat today. Its a Bravo 1 in front of a 575HP.
Is there a break in for a new drive like a tranny? Or just have at it and check the oil ?
JBoat is offline
Old 07-16-2010 | 09:18 AM
Is it a regular bravo 1 ? if it is baby it.....575 normally came with XR
SkaterMike82 is offline
Old 07-16-2010 | 09:26 AM
Yes. regular B1. first one made it 6 years did not want to get into a gimbal swamp in the middle of july or I would have went to a XR.
JBoat is offline
Old 07-16-2010 | 10:15 AM
Lotsa luck. My Bravo 1 lasted 7 hours after I repowered to a 525. The XR seems to be holding up. Boat is only 22'. You could give new meaning to the term "break in"!
thirdchildhood is offline
Old 07-19-2010 | 01:08 PM
New drive is on and seems to be doing fine. I put just over a hour on it and took it out for a fluid change saturday.
Only one thing that is bugging me, my idle rpm jumped up quite a bit. Its a efi motor and we only changed the drive. Would a new drive have less resistance of something?
I have had the boat 4 years and never had a idle issue, just swamped the drive and its high now ..
JBoat is offline
Old 07-19-2010 | 01:28 PM
obnoxus's Avatar
Charter Member #1171
same gear ratio?
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 07-19-2010 | 02:42 PM
You do NOT need to change Gimbals to go to an XR. Just the Gimabl bearing. It should not need any real break in. Just take it easy the first hour or so.
Griff is offline
Old 07-19-2010 | 02:52 PM
griff.. I wish I knew that a week ago. Oh well now I just have to figure out this idle.
same gear ratio. 1.50 came off 1.50 when on.
JBoat is offline
