Rinker Captiva 262 SS performance ???
I recently purchased a pretty rare boat and finding specs or even articles has been pretty tough. The few blurbs I have found online have pretty much come from searching here. http://www.offshoreonly.com/forums/g...ance-boat.html
I am hoping to get some info from you guys.
2002 Rinker Captiva 262 SS, 496 MAG (base) Bravo 1, 1.50, 15.25X24 4 blade Bravo 1 prop. 4800 pounds empty. The engine seems strong and runs smooth throughout the rev range. Whole boat has 40 hours.
From what I see, this boat should run at least 60 or better. My best has been 51 on GPS at about 4500 rpm. It acts like it's over propped in my limited opinion. I'm not sure if I am down on power or this boat really isn't as fast as I have heard it to be.
Does anybody have thoughts on this?
PS- here are some recent pictures
PS-my buddy was out yesterday with hos Baja 272 Islander 502, 420hp. With his labbed prop he is hitting 72-74 on GPS. That boat is even heavier than mine.
It just seems to me like there is a problem
Pretty low hours for an '02 boat. Did you do a thorough look through, plugs, plug wires, cap/rotor? Bots tend to get a bit old just sitting around. Could be the injectors are a bit dirty as well. Maybe it just needs a few tanks of fuel and run time. Very strong old engine, and that's a heavy boat.
I have run about 60-80 gallons of fresh gas through it so far.
Good to know. I will head over this morning and check these things out. I may be able to get some fresh plugs in today. I am also gonna try a get a new water separator in.
When I asked about the specs for the boat they said they were having trouble locating them. Outside of weighing 4800 pounds, I don't know
I found that the idler pulley is on it's way out and throwing off a fair amount of fine black plastic around the front of the engine. This also includes throwing it into the flame arrestor where it is being ingested into the throttle body and intake.
I have ordered a new idler pulley and cleaned out the flame arrestor, throttle body bore and blade. Could this stufff have gotten elsewhere and be causing a problem/restriction?
