Can I use clamp on mufflers on my dry exhaust? >
Old 07-19-2010 | 01:09 AM
tggrounds's Avatar
Default Can I use clamp on mufflers on my dry exhaust?
I have 4" stainless marine dry exhaust, but I do have a fine mist of water that comes out of the end of the pipes.
tggrounds is offline
Old 07-19-2010 | 01:36 AM
tomas_wallin's Avatar
I just installed gibson bullets and they work awesome with only a very small amount of water! I dump most of the water through two 1" through hull dumps and only through a 10x2mm opening in the end of the exh pipes that passes through the mufflers.
They tend to get some color though...
tomas_wallin is offline
Old 07-21-2010 | 10:59 PM
tggrounds's Avatar
Thank you I will check in to those.
Do you have any pics of your 79 pantera that you can post?
Old 07-26-2010 | 09:14 AM
Ditto on the pics, I'd like to see how you did the 1" openings. I'm looking to do the same for my Baja.
ittledoo is offline
Old 07-26-2010 | 09:40 AM
Brad Zastrow's Avatar
There are very few reasons to run dry exhaust unless you have a reversion problem. Which can be corrected in other ways. Dry exhaust is insanely loud and will upset many people in the harbors. Which in turn will lead to more problems for all powerboaters. You will need a fair amount of water to exit the tails in order to not cook the mufflers.
Brad Zastrow is offline
Old 07-26-2010 | 10:50 AM
You should be able to drill a series of holes in the inner pipe at the tail pipe exit. This should give you enough water to keep the mufflers cool and also help to reduce the bark.
BenPerfected is offline
Old 07-26-2010 | 03:40 PM
tggrounds's Avatar
This is my 3rd set of exhaust from stainless marine and finely no reversion, my engine guy said I need run dry but it is much to loud in the harbor and for me some times.
