2002 Baja 25 outlaw - Need some help
I am a bit new to the boating world and recently purchased a 2002 25 Outlaw. So far the boat has been great, but yesterday we were out on the lake and when i went to start the boat back up a alarm went off. (beep...beep....beep) I checked all of the gauges and everything look fine. I found that the alarm went off when i gave it one or two clicks of throttle. (a few hundred more revs) When i was coming in the marina i noticed that the water temperature was 190 degrees. This boat normally runs in the 170 range.
Any thoughts on why this alarm is going off? Are these issues related. The boat has 200 hours on it and just got a new belt and a water impeller.
I am going to check the coolant level today the boat was obviously hot and it was also raining at the time.
Water pressure will also cause this. If your housing is wore on the fresh water pump and isn't moving enough water...Impellers go bad if you get into sand or suck in something abrasive. Might want to look there as well if it was running cooler then suddenly jumped up.
check fluilds. thats a good place to start. mine was running around 190 this weekend as well. its because of the 100 degree weather and the 85 degree water. when you start going over 190 is when i would say there is a problem. good luck on stopping the very annoying beeping.
Well..496 mag is closed cooling..it should not run hotter than 175*..really ever...fluids..also check heat exchanger for any impeller debris..those older engines would catch impeller pieces in there..the newer ones have an open center so the impeller pieces can pass through...make sure on the depth sounder thing..I have seen it happen before.
I think the alarm goes off at 190* or 200* , so that would be about where you were at there...
