Backfire In Rough Water >
Old 07-22-2010 | 08:41 AM
Default Backfire In Rough Water
Thanks for the replies!
pachanga27 is offline
Old 07-22-2010 | 09:20 AM
Maybe you need new spark plug wires and spark plugs. Your boat is older, so it may be time to change them.
UrbanDisturbance is offline
Old 07-22-2010 | 09:26 AM
had same problem, found loose connection on lanyard safety switch
srx 780 is offline
Old 07-22-2010 | 09:30 AM
If everything else checks out, I'd replace the coil - I had one that check fine on the bench, but when hot it would cut out at odd times. Vibration could do the same - lots of windings and a few connections in that coil.
apollard is offline
Old 07-22-2010 | 10:17 AM
definitely a wiring issue of some kind....Check all plugs switches connections ect
bobsbillets is offline
Old 07-22-2010 | 10:25 AM
ttt
Hmmmm I will check this guy too!
Old 07-22-2010 | 10:31 AM
seltzer's Avatar
U check the float bowls?
Buddys boat did same thing, dumping fuel into carb, adjusted floats problem went away.
seltzer is offline
Old 07-22-2010 | 01:21 PM
Rookie's Avatar
Yeah what he said.
Did you put a different carb on?
Rookie is offline
Old 07-22-2010 | 01:39 PM
That is what we were thinking yes its a new Holley 850 Marine carb out of the box no adjustment yet. Thanks for all the replys OSO Rocks!!
