New Boat Question.. 1st Baja >
Old 07-22-2010 | 07:50 PM
Default New Boat Question.. 1st Baja
I just bought a real nice 265 DVX this week and took it out for a spin. It rips out of the water but tops out about 51-52 mph. Is this correct? It feels like it should be getting more top-end. Any opinions on props? Anyone ever have one? I'm just looking for some info. Thanks
Browny0386 is offline
Old 07-22-2010 | 09:18 PM
What motor do you have? What RPM are you seeing? What prop are you spinning? Will help us help you.
Irishtornado is offline
Old 07-23-2010 | 12:17 AM
Have a pure stock 1990 265 dvx and it has never seen 50 on the gps. It's a 454/365 bravo 1 with mirage plus 21p. So if your getting 50+ your doing good.
hungupthespikes is offline
Old 07-23-2010 | 08:03 AM
When my old 265 Force had stock power(454 330hp) it ran about 52-53...I repowered with HP500 it ran 62-63..then I added a 250 B&M supercharger it ran about 67-68..very slow hull..I would say you are right on track..if you are running a 3 blade prop..change it to a 4 blade and you will see a much better riding and handling boat.
Bajapred is offline
Old 07-23-2010 | 01:03 PM
I have a stock 454, I believe its 330hp, I'm turning about 4200 rpm's with a 19 pitch prop. If I run a 4 blade what pitch is the best? Thanks Again
Old 07-23-2010 | 03:24 PM
Well, I'm not sure..My 265 also had a 19p mirage on it when I got it..with the HP500 I used a labbed 24p bravo 1 & with the 250 B&M addition I went to a 26p no lab...but the difference in the handling was unbelievable between the 3 & 4 blade with that hull..I have to guess that you need an 18p or 20p but not sure where to find one like that..Hydromotive starts at 19p and bravo 1 I think start at 22p for 4 blades..
Maybe someone else will have more insight on prop selection?
Bajapred is offline
Old 07-23-2010 | 08:31 PM
hi browny, If it's a 454 mag then it's a 454/365 hp, steel crank and better heads. most produce around 385 hp.
as for the props, the forums i've searched say 23p/3 blade for speed. (mid 50's)
lots of good talk on the 4 blades like bajapred said. most are higher hp.
if i can get my backside up and moving this summer i'll call bblades.com and work out a good prop.
will let you know the results, but it''s been a busy summer and doesn't look good for boating.
