Bravo One gear damage in upper and wondering what tends to cause this... >
Old 07-25-2010 | 05:58 PM
Default Bravo One gear damage in upper and wondering what tends to cause this...
So my B1 drive went 'knock knock knock'. So I shut 'er down. Jump into the Atlantic and tried to turn prop. She was frozen.
Upper unit checked and there was gear damage.
What are some ways this damage could occur? I'm staring at 1500 bucks for parts and then some for labor.
Once I did a reverse to forward slam by accident (panic) when a 35' Fountain was about to spear me. My buddy did something similar in a panic (in my boat) when we were loading onto a trailer in a bad storm and winds were blowing him around.
Philster is offline
Old 07-26-2010 | 01:23 AM
That will cause it if the throttle was not at idle when it was shifted.
The upper gears are the weak point in Bravo 1 and they do just break under normal use as well.
Griff is offline
Old 07-26-2010 | 04:24 PM
Is that true for the uppers on the Bravo XR's as well.
J.P. is offline
Old 07-26-2010 | 09:23 PM
They're not that great either....I've went through a few sets
JaayTeee is offline
Old 07-26-2010 | 10:01 PM
100 hr xr gears, 525
Attached Thumbnails Bravo One gear damage in upper and wondering what tends to cause this...-xr.jpg
prostock85 is offline
Old 07-27-2010 | 08:39 AM
Did you break the case too ?
JaayTeee is offline
Old 07-27-2010 | 09:09 AM
JT,
I'd like you to take a look at mine this winter, just to make sure everything is ok. I havn't had any problems, but after Seeing what happened to Dave last week, I'd like to avoid it. Mine is a XR.
-Shane
cabin fever is offline
Old 07-27-2010 | 09:47 AM
Originally Posted by cabin fever
JT,
-Shane
Thats fine.
In the mean time, check the magnet on the drain plug for
metal particals periodically.
When the gears start falling apart, the magnet will tell you.
JaayTeee is offline
Old 07-27-2010 | 11:10 AM
Will do.
thanks man.
Old 07-27-2010 | 12:03 PM
BZ's Avatar
BZ
I should start a collection of those gear set's
BZ is offline
