New SBC/Melling H. Volume Oil Pump >
Old 05-02-2002 | 07:33 PM
BAD-HABIT's Avatar
Default New SBC/Melling H. Volume Oil Pump
What kind of Oil pressure should I be getting with a NEW engine with a High Volume Melling Pump? Im running 75+ when cold and 65+ after 30-40 Minutes. This seems awfull high!!! Thoughts????
BAD-HABIT is offline
Old 05-03-2002 | 02:45 PM
GregP's Avatar
The pump internal pressure relief is probably set at 75 psi (same as my BBC pumps from Melling). I have the same kind of running pressures. I've come to the conclusion that the HV pumps are really too much unless your running pretty big clearances.
-Greg
GregP is offline
Old 05-03-2002 | 09:55 PM
F3lS,
I have a federal mogual high volume oil pump on my sbc. I think to get a real reading you need a mechanical guage. My electric guage is 20 at idle and 40 from 2000 rpm up. The pressure appears to be ramped differently from my stock merc oil pump.
FlyFast is offline
Old 05-05-2002 | 01:08 PM
traviss's Avatar
the melling SBC high vol. oil pump comes with a high pressure spring in it, you have to change the spring with the extra one in the box, the extra spring wil give you standard pressure. Already changed mine.
travis
traviss is offline
DORaymond
16
09-09-2006 06:30 PM
QUIKDECISION
7
05-08-2005 11:26 AM
FlyFast
4
08-09-2004 11:52 AM
kmiller
3
06-23-2004 07:57 PM
27 FOUNTAIN
12
01-18-2002 07:25 PM
