Go Back  Offshoreonly.com > Owners Forum > Sonic
Net for front v-berth on 31ss >
Old 07-31-2010 | 08:32 AM
Default Net for front v-berth on 31ss
What is everyone using for a net to retain all the "stuff" in the v-berth? I am getting tired of picking up after each time of getting on plane. Would like to use a net of some sort. Some people suggest a Pro net for tail gates but I am curious what else is out there...
teamsynergy is offline
Old 07-31-2010 | 09:12 AM
Plum_Crazy's Avatar
I don't know what you carry up in the v-berth. But, I carry 4 fold-up chairs in bags, 4 big bumpers, a folding step, a step bumper, and floating chairs. When all that stuff slides back together is puts a lot of weight on the net. I don't think a regular springy net would be up to the task. But, the Pro-net sure is. If you mount it as low as possible in between the cushions, you don't even have to undo it to get to your stuff. You can just pull it over the top. Pro-net also sells optional quick-release tabs that make it easy to remove.
http://www.carcoverusa.com/Pro-Net-Tailgate-Nets.html
Plum_Crazy is offline
Old 07-31-2010 | 09:24 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I've got a cargo net from the trunk of a Pontiac Grand Prix stretched across my v-berth.
Sydwayz is offline
Old 07-31-2010 | 09:37 AM
Plum, what size did you go with?
Old 07-31-2010 | 11:40 AM
Plum_Crazy's Avatar
The mid-size. I think the small would work, but I wanted more net against the wall for support.
Old 07-31-2010 | 12:57 PM
Thanks for the info...
Old 07-31-2010 | 03:12 PM
hp500efi's Avatar
Member #9
Plum, how did you attach the net?
Member of the Liquid Jungle
hp500efi is offline
Old 07-31-2010 | 10:25 PM
Plum_Crazy's Avatar
Old 08-01-2010 | 11:55 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I could not bring myself to drill into my boat. I am using those little plastic 3M hooks with sticky tape that you get from Lowes/Home Depot. They have held for a couple years now.
Sydwayz is offline
Old 08-04-2010 | 09:29 PM
I did the same as Plum Crazy, worked out well. Thanks
WING TRANSPORT is offline
