Replacement Engine >
Replacement Engine
Replacement Engine
Old 08-03-2010 | 11:18 AM
JMG
Default Replacement Engine
Hi All
My 1988 454 Mag seems to have eaten its camshaft.
Tech says exhaust lifters on cyls. 5 & 7 are sticking (almost no valve movement on cyl. 7, less than normal on cyl. 5).
Yet I believe the cam is gone.. I'll pull the Intake next weekend to verify.
If it comes to the worst I'm thinking of buying a new long block.
What is a good place to buy such an engine (one that would ship overseas)?
Any experience with http://www.perfprotech.com ?
Thanks for your input
JMG is offline
Old 08-05-2010 | 07:28 AM
mrv8outboard's Avatar
coolrunning racing
Mercruiser has a 383 stroker,fuel injected with the dry joint exhaust. It make 350 HP and 390 Ft lbs of torque. They also have it in a 357, carbed, wet joint exhaust and that is 325 Hp 390 Ft lbs of torque. Just plug and play.
mrv8outboard is offline
Old 08-05-2010 | 08:31 AM
Go with the long block 454 or 502. You will spend much more converting to a small block........only to lose power.
Might try Derebery Performance.
TexomaPowerboater is offline
Old 08-05-2010 | 12:18 PM
If you think the cam went flat, cut open the oil filter that will tell you will fast.
Check into 1800runsnew They ship anywhere and are on the east coast.
I bought 2 502 base marine engines and they have the good parts. I took them apart to change cams, springs and retainers.
1BIGJIM is offline
Old 08-08-2010 | 07:01 AM
Originally Posted by JMG
Hi All
Typical result from a low zinc lubricant or soft cam.
Ken
minxguy is offline
Old 08-08-2010 | 07:23 AM
wantsa311's Avatar
Why not just put in a new cam and lifter set?
wantsa311 is offline
Old 08-08-2010 | 11:47 AM
I've done that in a car before. 3 months later it ate rod bearing. I'm sure the metal in the oil had a lot to with it.
I would say its 50/50 whether the rest of the engine bearings will last.
Griff is offline
Old 08-08-2010 | 12:33 PM
Yep, it you ate a cam the block should be boiled out. No way you can get rid of all the shavings. I would rebuild what you have but do a roller cam conversion. If you want more power give RMbuilder a call.
jeffswav is offline
Old 08-08-2010 | 07:07 PM
wantsa311's Avatar
I completely understand your point. if he's on a low budget it might work. I did a replacement cam in an engine that ran fine until I sold the car years later. Cams are cheap, I've got two 454 magnum cams in my basement he can practice with. :P
Old 08-08-2010 | 08:37 PM
Whatever you do, make sure you replace the oil cooler. You will not get all of the metal shavings out of it.
Eddie
Young Performance is offline
