502 mag engine temp?? >
Old 08-03-2010 | 12:32 PM
Default 502 mag engine temp??
I just picked up a 1999 38zx with 502 mags.
both engines run between 170-180 deg. Is this considered normal range?
Thanks Scott
SLAZARZ is offline
Old 08-04-2010 | 08:28 AM
My '99 454 runs 165-170.
Ken
minxguy is offline
Old 08-19-2010 | 02:14 PM
anyone else?
SLAZARZ is offline
Old 08-19-2010 | 02:33 PM
onesickpantera's Avatar
Mine ran about 150 and up to 160 after a hard run.
onesickpantera is offline
Old 08-19-2010 | 03:02 PM
mine are EFI's and run 170-180 ...I believe they should have 180 thermostats,
WR-1 is offline
Old 08-19-2010 | 03:51 PM
I believe the 502 Mag should run 807252T2 which is a 160* thermostat. Mine may have run 160 and 170 after a hard run(it was a few brain cells ago) I know they didn't run 180 ever. Not saying good or bad, just saying.
Old 08-19-2010 | 10:02 PM
My 502mpi's run 165-175 on the gauges. I wouldn't worry about 170-180* as long as they are consistent.
Griff is offline
Old 08-20-2010 | 07:12 AM
jjj
My 454 mpi with fwc runs 170-180 also(mostly just under 180)
jjj is offline
Old 08-20-2010 | 09:00 AM
DMAX's Avatar
Thanks Scott
Thats where mine run also, when running hard, with 260 Oil temp . Than head way speed water temp. 155, 160.
DMAX is offline
Old 08-20-2010 | 07:12 PM
Smitty's Avatar
Might be time for new sea pump impellers.
Smitty is offline
