Drive Reservoir Leak >
Old 08-04-2010 | 12:36 AM
carter38's Avatar
Default Drive Reservoir Leak
Having a problem with the reservoir leaking into the bildge. So far it's not the reservoir itself thought it might be front seal on drive pulled it it's dry. Is there a way this might be pressuring up and forcing it out the reservoir underway?
Thanks!
carter38 is offline
Old 08-04-2010 | 01:13 AM
Just a shot in the dark, but your cap might be bad. I just had this same problem and found that the seal was dry rotted. I changed the reservoir cap and knock on wood problem fixed
F1-00 Racing is offline
Old 08-04-2010 | 01:51 AM
carter38's Avatar
Man I was just wondering that if it might not be venting properly.
carter38 is offline
Old 08-04-2010 | 06:17 AM
Quinlan's Avatar
So about that pully?
And did I say your chit is LOUD!!!
Thanks for the ride
Quinlan is offline
Old 08-04-2010 | 06:22 AM
carter38's Avatar
Thanks for the ride
I think I got the pulley figured out and ya people keep telling me how loud it is thinking about naming it "Quiet Please"!!!! You guys are welcome anytime we had a blast!
carter38 is offline
Old 08-04-2010 | 08:05 AM
LV's Avatar
LV
I have the same problem leaking into my bildge, and the Gun is looking and sounding good!
LV is offline
Old 08-04-2010 | 10:15 AM
carter38's Avatar
Thanks man yours looks sick with that new paint!!!!!
carter38 is offline
Old 08-04-2010 | 10:23 AM
Which drive oil reservoir do you have? Some are prone to cracking. Also, we only fill ours to about 50-60% full when cool to allow for expansion.
BenPerfected is offline
Old 08-04-2010 | 06:25 PM
waybomb's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
What drives are y'all talking about?
waybomb is offline
Old 08-04-2010 | 07:43 PM
Reeking Havoc's Avatar
one of mine is doing same thing i pulled off inspected for cracks filled it up and let it sit on the bench for a few days and didn't lose a drop??? i can't see to inspect rubber hose to see if crack in there but from what i see hose looks to be good?
Reeking Havoc is offline
