Side Air vents for engine compartment?? >
Old 08-04-2010 | 09:48 AM
Default Side Air vents for engine compartment??
Where can I purchase these? They dont have to be exact because I'm going to replace all 6.
Carguy08 is offline
Old 08-04-2010 | 10:11 AM
Wobble's Avatar
SORE MEMBER
west marine has something like that.
http://www.westmarine.com/webapp/wcs...classNum=10666
Wobble is offline
Old 08-04-2010 | 10:34 AM
rchevelle71's Avatar
Is that really a Nortech with WalMart Vents
I would upgrade them, some of the ones in the below link should have the same size/screw pattern.
http://www.eddiemarine.com/store/car...ts&search=vent
rchevelle71 is offline
Old 08-04-2010 | 10:36 AM
Well you can try either of these vendors.
I'm pretty sure those look like vents I've seen at Dana Marine.
Dana Marine
Eddie Marine
KAP
kap328 is offline
Old 08-04-2010 | 11:04 AM
BigSilverCat's Avatar
We can machine you some of these..
they are polished stainless. made to fit right in the same spot
Attached Thumbnails Side Air vents for engine compartment??-side-vent-1.jpg   Side Air vents for engine compartment??-side-vent-2.jpg   Side Air vents for engine compartment??-side-vent-3.jpg
BigSilverCat is offline
Old 08-04-2010 | 11:09 AM
EMI is the only company that I have found that makes them the exact same size as the Attwood vents, unless you go with custom made like BYC offers.
http://www.eddiemarine.com/store/car...&p=12233&c=125
Griff is online now
Old 08-04-2010 | 11:40 AM
Wobble's Avatar
SORE MEMBER
it says they dont fit the blower vent covers, kind of defeats the purpose.
Wobble is offline
Old 08-04-2010 | 09:45 PM
http://www.eddiemarine.com/store/car...&p=12214&c=125
Went with the upgraded aluminum to match the paint. Thanks for all the suggestions. Will be here Friday. Thanks Eddie Marine and for all the suggestions.
Carguy08 is offline
Old 08-04-2010 | 10:53 PM
That would be blower vent collars. All you need to do is is use a few zip ties to hold the vent tube in place near the vent. Mine already have the Attwood collars and they work.
Griff is online now
Old 08-04-2010 | 11:05 PM
Wobble's Avatar
SORE MEMBER
you are correct, just wondered why they wouldnt incorporate such an important safety consideration. Not much point running the blowers if the "potential fumes" are not being properly exhausted.
Wobble is offline
