High altitude prop change/trade >
Old 08-14-2010 | 09:33 AM
Default High altitude prop change/trade
I just took my boat out here in the Denver area and was amazed at the power lost at altitude!!! I have a Hallett 260 with a 525efi and could barely get out of the hole. I calculated at about 6000ft a power loss of 90hp!!! So... I am running a 23p 4 blade and need to go down but how much? I have a 25p mirage plus never used ,I can trade in or switch if anyone is interested.
prozach is offline
Old 08-14-2010 | 12:27 PM
How much pitch to go down depends on what rpm you are spinning at WOT.
A 26' boat with a 525EFI only spinning a 23" prop sounds off to me already. Do you know what gear ratio your drive is???
Griff is offline
Old 08-15-2010 | 10:01 AM
I have a 1.5:1 xr drive. The boat was slow out of the hole at Havasu altitude but not too bad. With the boat empty, it would max at 5200 rpm.
prozach is offline
Old 08-15-2010 | 11:51 AM
If your 90hp loss calculation is correct, then you should be able to use a 21" prop of the same model prop. 60-70hp is usually worth about 2" of pitch.
Griff is offline
