Livorsi water pressure gauge.... >
Old 08-15-2010 | 04:58 PM
Rookie's Avatar
Default Livorsi water pressure gauge....
One of my Livorsi water pressure gauges is zeroed out a 10lbs. Is there a way I can just rezero it my self? They are a few years old but I just used installed it and after 1 day of use it did this. Maybe I should have just kept my cheap gauges in.
Rookie is offline
Old 08-15-2010 | 05:57 PM
I would ship it back to Livorsi, they likely won't charge you to repair it.
BenPerfected is offline
Old 08-15-2010 | 07:34 PM
johnnyboatman's Avatar
Did U Blow Air Into It
johnnyboatman is offline
Old 08-15-2010 | 08:50 PM
Tinkerer's Avatar
Did you remove the hose from the back of the guage?
If might have some dirt in the hose going to the guage holding the pressure at 10 PSI
Tinkerer is offline
Old 08-16-2010 | 01:20 AM
Disconnect the pressure hose and see if it goes back to zero.
Griff is offline
Old 08-16-2010 | 06:35 AM
Might have frozen during winter. Mine did this. Now I blow water out of the lines during winterization.
SkiDoc is offline
Old 08-16-2010 | 08:07 PM
Rookie's Avatar
Thanks guys, it's still accurate just 10lbs is the new 0lbs. I disconnected it and did not change. I put 10lbs to it and and it read 20lbs pressure drops off fast when pressure is released. I guess this winter I will send it back and see what they say.
Rookie is offline
